Sewer gas smell - no water leaking
Discussion in 'Toilet Forum discussions' started by Colin, Jan 24, 2005.
  1. Colin
    Colin New Member
    Jan 24, 2005
    My contractor just finished a basement re-model including a new three piece bathroom. When he roughed in the toilet he got his measurements wrong and the center of the flange is about 11" from the finished wall. Doh! To remedy this I got him to install the bowl and tank as I could not fit it. However, since the install I've been smelling sewer gas. I'm convinced it is the gasket, though there are no signs of a water leak? Is this possible?
    I've ruled out the following:
    1. Vanity sink -- trap is full and no odor
    2. Shower -- trap is full, there's no odor and it has been in place for weeks with no gas smell
    3. Laundry drain -- same as the shower as the trap is full, there's no odor and it too has been in place for weeks with no gas smell
    4. Gas furnace -- just had a leak test and a repair (for a flexible line the "contractor" kinked up) so that's not it either.
    Overall, my question is as follows: is it possible to have a sewer gas leak at the gasket but no signs of water leakage? Before we installed the toilet we plugged the flange with a damp rag and had no smell. Ever since installing the toilet we've had the gas smell. Makes me think that the contractor's install was less than optimal given the 11" rough in. I'm thinking that I might be better off buying a bowl with a 10" rough in requirement.
    Thoughts? Ideas?
    Thanks in advance for the assistance.
  2. Plumber2000
    Plumber2000 Plumber
    Jan 13, 2005
    Eugene, Oregon
    Get the 10'" rough toilet, and reset the toilet with it, you can bet that sewer gas can enter the house if the seal on toilet did not seal correctly, this can happen and even if you have no water leakage.
  4. Colin
    Colin New Member
    Jan 24, 2005
    Thanks Plumber 2000. I've learned a lesson here ... hire a pro to do it right the first time!
Similar Threads: Sewer smell
Toilet Forum discussions Would one be able to smell sewer gas from a bad wax ring if the base is caulked? Dec 16, 2015
Toilet Forum discussions Help! Sewer smell coming from toilet every time its flushed - all toilets in house Aug 22, 2013
Toilet Forum discussions Return of sewer smell Oct 29, 2012
Toilet Forum discussions Random sewer gas smell May 13, 2011
Toilet Forum discussions Another toilet install resulting in sewer smell Jan 22, 2008
