Charlie P
I sheetrocked a room that has the sewage pump alarm in it, so during the process The wires at the alarm (The ones that go to the circuit breaker, the pump and the alarm) got all mixed up.
At first the breaker in the panel kept triping,then the electrician switched the wires around and the pump worked again but he disconnected the wires that went from the alarm float to the alarm box. The alarm box still would light up and sound a buzzer if you used the test switch (because it plugs into a 110 outlet) but if you lifted the float the alarm wouldn't go off.
But the pump was working so I was happy with that.
Well, now the pump is not working again. And if I can get the help here I wont be calling that electrician again.
I guess I need help for 2 thing (as of now)
#1, Can anyone draw me a diagram for what wires go where on the float alarm box?
#2...why would the pump stop working again when it was working fine?
Any help would be great because as of now paying someone to fix it is not an option.
thanks
thanks
