Set cast iron tub in mud??
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Kmoninger, Nov 4, 2009.
  1. Kmoninger
    Kmoninger New Member
    Nov 4, 2009
    Kansas City
    We are remodeling our 2nd floor bathroom and have purchased a 72" Toto cast iron tub. The tub will be placed in the corner of the room and our carpenter has built a surround and a plywood base. The subfloor is in good condition.
    Our plumber intends to place the tub in a bed of cement mud but I have heard it's better to place shims under the feet instead. What would you recommend? I appreciate if several of you experts can respond as I need to get advice quickly. The tub goes in on Monday!
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    If the tub has legs that's what I would support it by.
    John
  4. Grimace
    Grimace New Member
    Oct 26, 2007
    Lab tech
    Slater, Iowa
    I would think that the mud would help distribute the weight over a larger area.
  5. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    Why would Toto put legs on the tub if not to support it? It will also be supported by the rim.
    John
  6. Kmoninger
    Nov 4, 2009
    Kansas City
    Toto says
    The installation instructions from Toto say do NOT support the tub by the rim. If we use a mud bed, how will that help level the tub? The tub weighs over 300 lbs - wouldn't it just sink to the bottom of the mud bed?
  7. Cass
    Cass Plumber
    Nov 12, 2005
    Yes it would just sink...shim with composite shims...
    What does the instructions say about leveling...probably to place it on a level floor....
  8. hj
    tub
    Even if you do use a mud bed, and I have NEVER done so, you would still need to position the tub at the proper elevation until the mortar/cement hardened.
  9. Kmoninger
    Nov 4, 2009
    Kansas City
    Tub
    The instructions don't say HOW to level the tub, just to do it. I guess I'm going to let my guys do it the way they know how. Maybe the mud comes as the last step, after leveling. I'm sure glad I'm not the one who has to get it done!
  10. Kmoninger
    Nov 4, 2009
    Kansas City
    Tub
    The instructions don't say HOW to level the tub, just to do it. I guess I'm going to let my guys do it the way they know how. Maybe the mud comes as the last step, after leveling. I do not know.
    Total weight, with water, tile and one human will be something like 1,100 lbs. Apparently there's no issue with too much weight as far as the flooring is concerned. I've checked on psi for subfloors and we seem to be ok on that.
Similar Threads: cast iron
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Today at 1:12 PM
Plumbing Forum, Professional & DIY Advice Cast iron sewer problems. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron tub ledger board placement Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron riser to toilet flange Feb 5, 2017
Plumbing Forum, Professional & DIY Advice 1950s cast iron sewer line clogged Jan 28, 2017
