septic tank moisture leakage outside
SRM
SRM
Kingsport, TN
My husband & I bought our house last may. We were told that the septic was in good shape...
starting this winter we started smelling odor from our back yard where the septic is. our backyard goes down hill. we live on the side of a hill. I'm now seeing a daily moisture come out of the ground and running downhill. the grass around it is now coming in really green. I have the odor come out occasionally. Is this a sign of a bigger issue or should I call to have someone check out my tank and get it pumped out. We've never had a septic system before so this is all new to us.
Thank you!!
Ballvalve
northfork, california
Typically tanks get pumped and certified for a bank before a sale closes. Pumping it is a good start to finding the issue.
Steve Langler 101
Read my story below:
Hi,
Unfortunately I have alot of experience with this type of situation. In reponse to your problem I will say that pumping will not fix the problem. The field has failed which is very expensive 10-30K or more depending on where you live. If you read what I wrote on another blog you can see the solution is definitely not terralifting and the problem is caused by years of sewage buildup from the lack of digestion. Read below:
Best Septic Product to use by Far! Best tip you will get regarding this believe me.
Read my story below that i posted on anothe blog I believe it answers your questions:
I used to think like you that all septic tank additves were the way you described but recently I had experienced a totally different thing happened to me. I live in a house that is 43 years old in Connecticut. I have 3 kids and a wife. I had alot of friends over the years come by and visit my house. I have lived there for the past 15 years. Before me there was a family of about 5 as well. For 15 years I relied on pumpouts and used yeast or Rid x (along with other product ) which is basically the same thing except Rid x is bad because they add fillers. Anyhow, one day I noticed odors and backup inside my house so I pumped the tank like I had done for many years once every 3 years, The pumper and local officials told me never to add anything into the tank. When the pumper came this time he pumped the tank but run off came back into my tank from my field. So I ignored it even thought the pumper told me that my drainfiled was saturated, clogged and ruined. I asked him why and he didnt know. I did some research and called a co. which looked more reputable then the other co's which I saw online www.biosafeone.com a field tech there advised me that I needed to shock my system with their patented products that no other products would work. I was very skeptical and decided to wait. 2 weeks later the problems got worse there was a flood on top of my drainfield and black biomat shot up out of the ground as the biosafeone tech said would happen. I was very afraid of getting code enforced by the local health dept. which they would have mandated a new drainfield with a contractor which would have cost me $35,000, I did get three quotes from contractors they each tried to low ball me but I knew better they told me $8K for a new field but my neighbor Jim told me that was baloney that a new septic system would be about $35K. Contractors always quote low and charge high! I tried to first save some money with some cheaper septic products but nothing worked. Then I called back biosafeone is a desapate attempt to fix my septic system. Biosafeone was not cheap but turned out to be worth every penny!
I called back BioSafeOne to order biosafeone products after all of biosafeone's references that were given to me came back very positive but I was still skeptical because nothing else had worked at this point.Yet all the references spoke highly of the biosafeone products. So I deceided to shock my system using 11 pails of their BIO-112 Heavy Sludge Digester along with their 3 Yr. BOSS product and 1 Biocube . Within 2 weeks all the flood had dried up within 3 days all backups and odors were gone. I was totally amazed in shock!! I could not believe how well the products reversed 43 years of sewage buildup! Just goes to show you the big lie is dont add anything to your septic and everything will be fine just pump it. I found out later that my pumper was directly related to the replacement guy. He was mad that I didnt hire him too. How ironic. My conclusion is that it is one VERY BIG LIE and MISCONSCEPTION TO NOT ADD ANYTHING TO YOUR SEPTIC TANK TO MAINTAIN. Another big lie iis to just rely on pumpouts nothing could be further from the truth. The local government, pumpers and replacement people all profit when the system fails so they tell you this to expect your system to fail in time. The Biosafeone tech explained to me that when their BOSS product is used from day one total and complete digestion occurs of all incoming waste therefore nothing accumulates in the tank or field or pipes so obviously there is nothing to pump out and even better no big replacement bill. I totally refute all other comments on this page if you havent tried these biosafeone.com products then you really have missed something! Thank you so much Biosafeone for saving me a fortune ! You guys are great!
