Securing gas pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by MarkS, Jan 12, 2007.
  1. MarkS
    MarkS New Member
    Jan 12, 2007
    In my basement, all the natural gas lines (black pipe) run up in ceiling and are secured to the joist.
    At the end of the line there is a 90 degree elbow which points down towards the floor. Off the elbow hangs about 6 feet of black pipe with a connection at the bottom for the gas dryer.
    This 6 foot of pipe just hangs off the elbow, it is not fastened to the basement wall. The pipe actually has some movement several inches to each side.
    I'm wondering if this was by design? I was thinking of just securing the pipe to the basement wall to prevent it from moving (and maybe cracking the elbow), but then I thought it was left loose to give room for expansion between the basement wall and the joist.
    It has probably been like this for several decades :) I just noticed because I'm am replacing my electric dryer with a gas model.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    It probably isn't necessary unless there is a possibility that the leg will be subjected to some pretty heavy duty movement. On the other hand, it wouldn't hurt anything to attach the lower end to the wall to prevent it from moving.
  4. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    It may not be necessary to strap it, but unstrapped it wouldn't pass a proper inspection.
Similar Threads: Securing pipe
Plumbing Forum, Professional & DIY Advice securing copper pipe Mar 24, 2013
Plumbing Forum, Professional & DIY Advice Securing vertical ABS pipe Dec 31, 2010
Plumbing Forum, Professional & DIY Advice Securing a copper pipe riser May 20, 2006
Plumbing Forum, Professional & DIY Advice Securing vintage sink to the pedestal Mar 6, 2016
Plumbing Forum, Professional & DIY Advice Securing PEX Nov 6, 2015
