MaxBlack
I say if it's now working to your satisfaction then don't sweat the pressure switch setting--it's possible, nay likely, that the guage isn't giving you perfect readings either; they get crudded-up and aren't accurate...domingum said:I want to make sure I don't damage the pump. My pump is a Sears 1/2 hp, and on the side it says "Pressure 20 / 40". Yet the pressure switch is currently turning the pump on at 30 lbs and off at 54 lbs. Is this OK for the pump or will it damage it? What is the correct setting for the pressure switch?
The main thing is, you don't want to short-cycle the pump. If the pump is running at least a couple minutes when it does come on then "that's a good thing".
