sealing roof jack
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chetwynd, Mar 17, 2006.
  1. chetwynd
    chetwynd New Member
    Jul 27, 2005
    California
    Hi,
    The project I'm working on is actually electrical, but the same question applies. I have a piece of galvanized 3/4" pipe going down into a roof jack on a garage. Right now it's sealed with some kind of tar or putty or something that looks like it's been there forever. I need to replace the piece of galvanized pipe, and will then have to reseal where the pipe goes down into the roofjack. What should I use? 20mil tape?
    Talk to me fellas!
    THANKS!
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    use silicone
    jsut buy a tube of clear silicone
    it works great
  4. hj
    seal
    Or a tube or can of roofing cement.
  5. Cass
    Cass Plumber
    Nov 12, 2005
    Thoes will do the job.
  6. modbit
    modbit New Member
    Jun 26, 2012
    Atlanta
    That will work or roofing bull.
  7. bluebinky
    bluebinky Member
    Aug 31, 2011
    Software Engineer
    Santa Clara, CA
    Just in case you didn't already know, you should use rigid conduit instead of plumbing pipe for electrical.
    Of course, that has nothing to do with sealing the roof penetration...
  8. hj
    The only real difference is that electical conduit has a straight thread, but I do NOT think electrical nipples are any different than plumbing ones.
  9. bluebinky
    bluebinky Member
    Aug 31, 2011
    Software Engineer
    Santa Clara, CA
    Plumbing pipe isn't "approved" for electrical work. Not a big deal, other than an inspector might notice...
  10. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    Electrical conduit is deburred, both at the threaded ends and internally. That is most emphatically not the case with the plumbing nipples sold
    most places, which could easily damage wiring pulled thru them. It is a big deal.
Similar Threads: sealing roof
Plumbing Forum, Professional & DIY Advice Sealing pipe threads with large gap Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Fernco/No-Hub not sealing on cast iron Nov 30, 2015
Plumbing Forum, Professional & DIY Advice Reinstalling undermount sink: sealing the frame properly? Aug 14, 2015
Plumbing Forum, Professional & DIY Advice Sealing Around Copper Penetration Nov 16, 2014
Plumbing Forum, Professional & DIY Advice Tub drain sealing advice. May 20, 2014
