Schedule 40 Under Driveway???
Jeff112
North Carolina
I will deeply appreciate any help. I have just finished excavating a lot to build a house. Within the month a 1000 gallon septic system installed with 320' of fill lines. It's approved for 3 bedrooms although the house is only 2 BR, 1.5 Bath. Here is my question. The HOA allows RVs to be lived in while the house is being constructed however I would like to build a "tiny house" that could be utilized later for company. To run a sewer drain from the tiny home to the septic tank, approx. 8-10 ft will be under the driveway. Can I use 3" schedule 40 and be confident if installed correctly it will handle being driven over or should I encase the drain pipe in either iron or steal pipe? Thanks in advance. Jeff
Breplum
Licensed plumbing contractor
San Francisco Bay Area
In many of our local jurisdictions around here, anything beyond the building must be 4" and have a cleanout every 135 degrees of turn.
Depth and proper trench support and backfill are part of the things to factor.
I don't want to certify your application (I suspect you will be plenty fine), but I wanted to point out that PVC pipe comes in foamcore, which is rated for DWV. It also comes in double-rated solid PVC, which is stronger, and rated for pressure in addition to DWV.
There is also PVC pipe that is thinner, and by using schedule 40, you are already ahead of average.
