Sayco shower diverter - removal
Discussion in 'Remodel Forum & Blog' started by eterry, Nov 10, 2008.
  1. eterry
    eterry New Member
    Nov 10, 2008
    Can't remove the Sayco diverter stem from my shower. It just keeps spinning. Any suggestions other than tear out the tile and put in a whole new faucet system?
    Thanks
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Is the stem loose (unthreaded) but just not coming out of the valve body?
  4. eterry
    eterry New Member
    Nov 10, 2008
    Yes, the stem is loose - will spin and spin; but won't come out. Have tapped, pulled and tugged, but can't get it out.
  5. Redwood
    Dec 15, 2007
    Service Plumber
    There is a plastic washer that is probably hanging up coming out of the valve body. Turn the stem so that it is in the full open position. This will line up the plastic washer better. It still may require some wiggling and pulling to get it out but should be easier.
  6. hj
    stem
    WE don't know if you are removing it properly. DId you unscrew the entire component, or just the packing nut and are trying to remove the stem through that opening?
  7. eterry
    eterry New Member
    Nov 10, 2008
    I've tried to unscrew every component that I can. It appears to be down to just the last long stem piece and the part that is connected back inside the main pipes. {After a while, I put the one larger section back on it and tighten it a little so I can operate the shower.}
  8. hj
    faucet
    A picture of what you are doing would be helpful. If you have unscrewed the proper part, it should pull out, even if it requires more than normal force. If you have not accessed the correct part, you may have damaged the diverter and will need a new one. Sayco made several valves and they all look the same, but they are different so you need to use the old one as a pattern.
  9. eterry
    eterry New Member
    Nov 10, 2008
    I had purchased the a new one at Home Depot. I was changing the diverters in the hot and cold water faucets. I was using the 9B 3H (3C) and the diverter for the shower was 9B 5D.
  10. WadeTenbrink
    WadeTenbrink New Member
    Apr 24, 2010
    bakersfield
    Did you ever find out why the diverter would not come out??? I am having the exact same problem with my sayco diverter. I easily removed the hot and cold stems but the diverter would not come out after it was completely loosened in the same same manner as the stems.
Similar Threads: Sayco shower
Remodel Forum & Blog Venting sink and shower on saniflo ?'s Feb 6, 2017
Remodel Forum & Blog Capping off old shower drain Sep 21, 2016
Remodel Forum & Blog Minimum gap between shower door and header Sep 2, 2016
Remodel Forum & Blog Mortar under shower pan - new question May 19, 2015
Remodel Forum & Blog Joist in the way of new shower drain Apr 1, 2015
