duckman1958
- Messages
- 2
- Reaction score
- 0
- Points
- 0
Looking to drive a sand point to use with a couple of sprinklers up at our hunting property; these will be used to irrigate small food plots.
I am not sure which route to go in terms of the pump here…we do NOT have power in the area, and use a smaller generator (Honda 2000i) for our power needs. Does it make sense to go with a small electric shallow well pump to run off of the generator or go with a pump which has a small self-contained motor (used in many cases to pump water from a creek or lake)?
Also, in this scenario will I need a pressure tank as well? This setup will not require more than 15 feet (at most) of draw from my sandpoint as water is readily available.
