Sand now in filter
Discussion in 'Pumps and Tanks Well Forum & Blog' started by kennyp1960, Oct 22, 2007.
  1. kennyp1960
    kennyp1960 New Member
    Oct 22, 2007
    Hi
    I have a existing well, been in the house @ 4 years the well and house is @ 20 years old, not sure of the depth of the well but the sub pump is set @ 150ft.
    Had a lack of water pressure, actually constant pressure. I replaced a old whole house filter that I could no longer easily get the filters for, after a few months I discovered I installed the filter canister backwards, the in to the out and out to the in(don't say it I already did).
    Well I fixed that and also checked the bladder in the tank, it had @ 27 psi so I increased that to match the low side of the pressure switch(40/60),I have it approximately @ 38/40 psi. The filter canister is filling up rather quickly with sand, I've checked and it seems like well the well pump comes on @ 20/30 secs later I get a quick burst of sand and then the water runs clean. Not sure if the sand is in the storage tank, since I had the filter backwards for some time or for some reason coming from the well. Any help would be appreciated.....Kenny
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    If your well is pumping sand and you don't want to replace it with one that doesn't produce sand, get rid of that inline filter and get a real filter. The sand will still eat your pump, but you will be free of sand in the house and you can quit buying those useless filter cartridges.
    bob...
Similar Threads: Sand filter
Pumps and Tanks Well Forum & Blog Centrifugal sand filter/CSV questions Mar 31, 2014
Pumps and Tanks Well Forum & Blog high iron well water with greensand filter Nov 12, 2012
Pumps and Tanks Well Forum & Blog Greensand Filters Dec 31, 2011
Pumps and Tanks Well Forum & Blog Sand in filter Oct 9, 2011
Pumps and Tanks Well Forum & Blog gravity underground sand filter Jun 17, 2011
