Salvaging Brick
Discussion in 'Remodel Forum & Blog' started by shimp, Mar 31, 2008.
  1. shimp
    shimp New Member
    Jan 27, 2008
    Kentucky
    hi neighbors
    im going to add on to my garage, the addition will be another bay.
    the exterior wall that im planning to join the new addition is brick on the outside.
    im planning to remove the brick, and would like to save as many as possible.
    what would be the method to remove the brick,and using what tools?
    thank you
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    The best method is to pull the bricks down in large panels and hire a couple of guys at the local day-job site to to knock off the mortar on a piece-work basis. You might be able to negotiate 10 to 25 cents per non-broken brick. If they aren't worth that to you then you can check what it costs to buy used bricks that have been cleaned.
  4. hj
    brick
    A 2" wide "flooring chisel" will usually separate them very neatly.
  5. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    It's likely that as long as you don't have an exotic brick you could buy reclaim cheaper than it would be to save what you have. Crazy isn't it.
    Tom
  6. shimp
    shimp New Member
    Jan 27, 2008
    Kentucky
    good thought re the reclaim, except i cant find it
  7. statjunk
    Jun 28, 2007
    Call the local mason shops and ask questions. Around here all the re-claim places are in the worst neighborhoods.
    Tom
Similar Threads: Salvaging Brick
Remodel Forum & Blog Bricks, withot mortar as a temporary hearth solution ? Nov 29, 2014
Remodel Forum & Blog encasing old bricks in new concrete? Aug 28, 2012
Remodel Forum & Blog Insulating Brick home in OK? Aug 3, 2012
Remodel Forum & Blog Hit a brick wall...could really use some advice Apr 1, 2012
Remodel Forum & Blog Hiding cables behind a brick wall Aug 2, 2011
