running pipes question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Michaela521, Feb 7, 2006.
  1. Michaela521
    Michaela521 Member
    Jul 16, 2005
    North Dakota
    Hi all, We are going to be moving our bathroom over because the location of it right know is awkward. I live in a Very cold area (freezing) and the toilet, tub, and shower are going to be located on a wall that is an exterior wall. piping such as supply and drainage cannot be run in a wall like this so the plan was to build another wall on this one that consisted of 2 by 6's and run the pipes in this wall. The wall would recieve a layer of sheetrock and tile when finished. Is there anything that you could add to help me out. Is this okay? Thanks alot. :cool:
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    If I have followed your plan correctly, you are going to increase the thickness of the wall which currently has 2x4 studs by sistering 2x6s to the 2x4s. That will work fine and give you room to put the plumbing in that wall. I would use R19 insulation with the plumbing on the inside of that to protect the pipes from freezing. If taking another couple of inches would be acceptable, you could even use 2x8 studs and have even more room for everything.
  4. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Visit www.johnbridge.com before you make a final decision on putting sheet rock under tile in a shower.
    It sounds like you are planning another full 2x6 wall inside the exterior wall. That seems like a bit of overkill.
  5. hj
    wall
    Before I would take that much space out of the bathroom, I would try to find other ways to accomplish it. The drains can go in the outside wall, so you just need to protect the water pipes. they would not need a 6" wall to do that. Is that layout of fixtures the only one that will fit the area?
Similar Threads: running pipes
Plumbing Forum, Professional & DIY Advice Reducing sound of water running in pipes throughout house Feb 12, 2015
Plumbing Forum, Professional & DIY Advice Banging pipes when running outdoor spigot. Darn kids.... Aug 25, 2014
Plumbing Forum, Professional & DIY Advice Hellow and knocking noise in water pipes when running dishwasher Nov 6, 2013
Plumbing Forum, Professional & DIY Advice Air in pipes? Nothing has been opened/drained. Could my Well be running dry? Sep 1, 2011
Plumbing Forum, Professional & DIY Advice Loud pipes when water is running Sep 28, 2009
