Rubber Gasket Around Tub
Discussion in 'Shower & Bathtub Forum & Blog' started by tweeder712, Aug 9, 2011.
  1. tweeder712
    tweeder712 New Member
    Aug 9, 2011
    Jersey
    I am installing a new Jacuzzi corner tub and someone mentioned that I get a "rubber gasket" for around the tub. I saw one at a friends house its shaped like a sideways "T" and was white. Is the proper name for this product, and where would I be able to purchase one?
    Thank you
  2. hj
    It is called a "tile flange" and you get if from the same company which made the tub.
  4. jadnashua
    If this is a drop-in tub that is also going to be used as a shower, then the tiling flange kit is what you need to keep water out of the walls, at least from the tub surface (there are other things that need to be done to make the whole thing waterproof in a shower situation). But, if it is only going to be used for soaking, this won't work. Someone might make a rubber gasket for under the lip to be used in a drop-in situation, but I'm not familiar with them.
  5. tweeder712
    Aug 9, 2011
    Jersey
    Thank you both, it is a drop in tub, that will be making into a shower as well.
  6. jadnashua
    If you haven't bought it yet, they probably make a version just like that one that has a factory tiling flange already installed (moulded in). That is the better choice. Also, you could use something like Dilex from www.schluter.com along with their Kerdi membrane to waterproof the walls.
Similar Threads: Rubber Gasket
Shower & Bathtub Forum & Blog Replacing Rubber Gasket Oct 7, 2008
Shower & Bathtub Forum & Blog drain and overflow rubber gasket problems.. Mar 21, 2008
Shower & Bathtub Forum & Blog Rubber Strainer Washer under Fibreglass Tub May 6, 2016
Shower & Bathtub Forum & Blog Bathtub drain leak brass rubber connection Nov 10, 2006
Shower & Bathtub Forum & Blog Replacing bathtub shoe gasket Nov 17, 2016
