roughing in basement
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by edmuhl, Apr 24, 2007.
  1. edmuhl
    edmuhl New Member
    Apr 24, 2007
    I'm going plumb my basement. Can I put my bathroom anywhere? It has a drain by the furnace and there is also a plate which covers what looks to be the sewerline.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You put the bathroom anywhere you can install a proper drain. That drain by the furnace may or may not be of value for this job. A toilet must have at least a 3" line and be vented. A shower needs a 2" vented line. Sinks and tubs need only a 1-1/2" vented line. Now the problem you have to solve is how to provide a 1/4" per foot slope to your drain lines. The further away from the main drain you want the bathroom, the deeper your trench between the bathroom and main drain must be. It would be wise on your part to have a plumbing contractor evaluate what you have and advise you on what can and what can not be done. You will be covering your drain with concrete and it had better be right before you do that. Remember, all things are possible...if your pockets are deep enough.
  4. EAP
    EAP New Member
    Sep 3, 2004
    Gary gave some great advice on consulting a pro. A basment bathroom
    especially with drains under the slab, is often outside the realm of a DIY project. Too many variables. You should also get yourself a book or two from the library that demonstrates this type of plumbing project. So you get a basic idea of the depth of the work involved. But the consulting pro is a definite must-see.
    Plumbers often have that sixth sense on where the drain lines run underneath the slab. Imagine picking a spot at random, breaking through the floor and missing the mark, or worse yet, breaking the pipe.
    You also have the option of using an ejector pump and pit or the toilets with a macerating pump. But these are best used in basements that have no underground plumbing. If the power goes out, so does the pump and the toilet and other fixtures connected to it.
    Breaking the floor even if it amounts to 20 square feet of broken concrete is not an easy task, very dirty, and then all the ruble and dirt needs to be disposed of. Of course, after the rough-in is approved by the inspector, then you need to close the trench. Another mess waiting.
    It's so much easier especially when building a new home, to have the drains roughed-in in the basement before the floor is poured. And a lot less expensive.
    Good luck.
Similar Threads: roughing basement
Plumbing Forum, Professional & DIY Advice Help with roughing in floor mount rear discharge toilet please Mar 13, 2016
Plumbing Forum, Professional & DIY Advice Roughing in Brizo shower body and diverter Jan 24, 2016
Plumbing Forum, Professional & DIY Advice Roughing in a new bathroom Dec 15, 2015
Plumbing Forum, Professional & DIY Advice Roughing in PE gas line before landscaping Dec 13, 2014
Plumbing Forum, Professional & DIY Advice Roughing in a pot filler with a filter? May 22, 2013
