Rough-in distance from wall for setting toilet
Discussion in 'Toilet Forum discussions' started by micalk, Aug 28, 2005.
  1. micalk
    micalk New Member
    Aug 28, 2005
    Electronics Engr
    Simi Valley, CA
    I bought a Toto that has a 12" rough-in. Does this mean 12" from the finished wall to the center of the toilet flange? How much clearance should this give me from the back edge of the tank/lid to the finished wall?
    Michael
  2. jimbo
    jimbo Plumber
    San Diego, CA
    Yes, the rough-in spec for a toilet refers to the distance from the finished wall surface ( not including baseboards) to the centerline of the waste flange. You can go online to any manufacturer and check the specs on their models. Typically, a toilet installed exactly at 12" would have anywhere between 1/4" and 3/4" clearance. The reason for some clearance is that the manufacturing tolerances on a large porcelain piece like a toilet are significant; and generally accepted industry tolerances on wall bow and plumb also come into play.
  4. alhurley
    alhurley Guest
    if you have the toilet in hand why don't you just measure it? :rolleyes:
    best be careful about that "finished wall" part - especially with Toto as the base tends to be very long on some models. I put a new Toto Drake in back in April and measured the rough at 12" - give or take a little. The Toto shop said "no problem, these rough-in dimensions aren't that precise. Easy for him to say - I was the one who had to trim out part of the baseboard to get the Drake to fit. I think my rough ended up being about 11-3/4". :eek:
    -art-
Similar Threads: Rough-in distance
Toilet Forum discussions How easy/hard/expensive to extend the rough-in distance a little? Sep 14, 2010
Toilet Forum discussions Odd rough-in distance Sep 18, 2008
Toilet Forum discussions Toilet Drain - Rough-In Distance from Wall Mar 6, 2008
Toilet Forum discussions Any round-bowl Toto toilets w/14" Unifit rough-in? Jun 9, 2016
Toilet Forum discussions Need Advice: 10-inch rough-in for small space Apr 23, 2016
