Right way to plumb tankless w/h?
Discussion in 'Tankless Water Heater Forum' started by Randyj, Jun 22, 2010.
  1. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    I've only installed one tankless water heater so don't know much about them. Is there truly a "right way" to plumb a tankless water heater? Should there be an expansion tank, check valve, pressure gauge, etc.???
  2. hj
    tankless heater does NOT have any stored water and it only heats while water is flowing, so it does not NEED an expansion tank, or check valve, and few even have provision for a temperature relief valve, although all of them come with a pressure relief valve. None of these are needed IF the heater is working properly, but then, safety devices are installed to take care of problems when things DO NOT operate properly.
  4. Scott D. Plumber
    Scott D. Plumber In the Trades
    Jun 30, 2009
    Find an instalation class in your your area for Noritz or Rinnai. They are usually free and are just what you need.
Similar Threads: Right plumb
Tankless Water Heater Forum Installing 2 Tankless - Did my plumber do it right? Sep 5, 2014
Tankless Water Heater Forum Is Navien 240B or Bosch Combi 151 right for me? Mar 7, 2015
Tankless Water Heater Forum Finding the Right Re-Circ Pump May 2, 2013
Tankless Water Heater Forum Need help making the right decision on tankless Jan 14, 2010
Tankless Water Heater Forum Extreme Hot water fluctuations in shower. 4 plumbers. No solution. Help! Jun 24, 2015
