Water leak error code on Rheem
nbaxley
Illinois
I've got a Rheem gas tankless model: ECOH200DVRHLP. I installed it myself a year and a half ago. It's been working just fine. Today I was replacing my water pressure tank and forgot to tun off the tankless unit before I drained the house to do the swap. About an hour later I realized it and turned it off. I noticed some water draining from the bottom of the front panel. I opened the panel and didn't see an obvious source. I finished the pressure tank job, and turned everything back on, but the tankless heater gave me an error code 45 (water leak). I dried up the water in the bottom of the tankless unit and I've had a fan on the open unit for about 6 hours, but restarting it still gives the same code. I've read about others on Reddit just waiting a longer time (18 hours) but I'm wondering if there's anything else I can do. How bad was it to run the tankless with no or little water in it for an hour and what kinds of damage might that have done, especially to cause a leak.
Thanks,
Nate Baxley
