Raucina
- Messages
- 515
- Reaction score
- 1
- Points
- 0
I have aquired an old gold mining property on a steep hillside that has what appears to have been a good well. No action in 30 years.There is little information available except that hung in the hole is a Jaquizzi 1.5 hp 2 wire pump. Owner says its 650' deep. Believes the static water level is 160'. GPM of well unknown. Pumping water level unknown. depth of casing unknown
Pump will not start, locked up. Assuming the well is not caved, and I pull it all out, how would you choose a pump? Would you drop a temp pump a few hundred feet and see if you can pull the water down to that level? Seems like too much work. I am used to new wells with logbooks available.
Set the pump at 5 or 600' and size it for some guestimate pumping level?
Use a low water shut off if you guessed wrong? Assume the previous pump guy new more and match his pump?
I will install a 3000g tank about 50psi worth up the hill so there need not be any issues of valves, pressure tanks and etc. - just a float valve. We are talking basic residential use here.
The neighbors wells dont reveal much, one can be 75' and the next 400' . There are so many old tunnels in these mountains that its not too unusual to drill into one.
The Grundfos rigs look nice [?] - soft start, variable, 3" diameter - 600$ on E-bay....What brand pump would you use in such a deep hole?
