replacing verticle cast with pvc
Jim Mills
nebraska
I have a 75 y/o 4" cast iron stack that services one bathroom group that needs help. The stack measures 24' from basement floor up through roof. I would like to cut the cast & replace the bottom 8', replacing the san tee & lead closet bend, and re configure the tub & lav drains, eliminating the lead drain lines. Question is how can I support the cast while cutting the section out, and will PVC support the weight of the 16' of cast above it? I can use no hub cast, but PVC would sure be easier
I would like to remove the entire stack, but the walls are finished all the way up through the attic dormer. Plaster & lathe, coves ceilings, plaster moldings. Just a nightmare...
