Replacing old p trap - new vanity
wolfpacknc
north carolina
Hi guys!
I am remodeling my bathroom. I purchased a new vanity that has exposed plumbing. I need to replace my existing drain connection with something that
1. fits the new 5/4" p-trap horizontal pipe
2. is chrome and can use a trim ring to cover the hole in the wall.
The problem is that this is a fairly old house and the current drain line is 7/4" and connects to in the wall to something that looks about 3" in diameter. <see pic>
I tried to remove the entire pipe that sticks out from the wall and it wont budge. I am able to slide the nut back towards the wall.
any ideas?
Thanks in advance!
Smooky
North Carolina
If you have exposed plumbing you need to get that nipple out. Try using a bigger pipe wrench or sometimes I slide a two to three foot section of pipe over the handle to get more leverage.
Cacher_Chick
Test, Don't Guess!
I cannot judge the sizes properly from the picture, but it looks to me that you have a 1-1/4" trap adapter screwed onto a 1-1/2" pipe nipple.
It will probably unscrew given enough pressure, but you could crack the cast iron pipe in the wall. This is something you have to have a feel for.
wolfpacknc
north carolina
The male coupler that protrudes from the wall is actually 1-3/4. I've soaked it down with pb blaster and still can't get it out. I used a 16" pipe wrench, so I guess I'll try a pipe extension on that to get more leverage.
So, assuming I can get this thing out what sort of adapter can I use. Can I get a pvc pipe to screw into the cast iron and reduce down to 1-1/4? The part that screws into the cast iron has a fine thread while the other end is a coarse thread. I haven't been able to find anything yet. But I'll probably need to try a specialty store when they re-open Monday. Can I find a p trap horizontal pipe that will go right into the cast iron connector in the wall?
thanks for the replies!
Jimbo
San Diego, CA
Every trade has "inside lingo"! We do not refer to pipes ad 5/4 etc like lumber. Also, we refer to pipes by the ID ( inside diameter). SO that pipe you call 1 3/4 is a 1½ pipe. It will help you immensely when you go shopping at a plumbing store if you can pick up a little on the lingo! They will know what you are talking about, and they will think YOU also know what you are talking about. If you walk in asking for a widget for a 1 3/4" pipe, it won't go well from there!
Just a helpful tip!
Browse the forum threads....we always try to use correct terminology, and WE don't mind if you ask questions when you don't understand!
Plastic pipes are rarely threaded, but fittings are. IF you can get out the galv. nipple, you could screw in a male PVC adapter and then glue in a street trap adapter 1½ to 1 1/4". This would shorten it all up a little.
For a picture of the two fittings I just mentioned, go to this PDF http://www.nibco.com/assets/plasticfit.pdf
see 4804 page 14 and 4801-2-7-C on page 12.
Cacher_Chick
Test, Don't Guess!
If you are going to install chrome plated brass or similar trap, everything you have there is already properly sized.
If you can get it out you could install a shorter nipple, but if removing that nipple is a problem, it could be covered by getting creative with a deep chrome or brass escutcheon.
wolfpacknc
north carolina
My ignorance has been revealed :). This is my first home and I'm trying to fix it up a little. We all gotta start somewhere I suppose. Thanks Jimbo! Those fittings look perfect. I had no idea what to put there even if I got the nipple out.
@cacher_chick, thanks. I'll try my local plumbing supply store when they open Monday.
I'm gonna try more to get that nipple out today.
IF you remove that 1 1/2" nipple without breaking the cast iron tee, then you need a brass MALE 1 1/2"x1 1/4" DeSanko/Marvel/trap adapter (whichever they call it where you live). Screw it into the tee and connect your trap.
wolfpacknc
north carolina
OK I got the adapter off. Now all I have is the nipple
If I try to remove this nipple then I will tear the threads up, so I am hesitant to try this. I guess I need to find an adapter that will mate the 1-1/4 trap adapter.
JohnjH2o1
Florida
You can use just the nipple. Just use a standard P trap, it will fit inside the nipple then use a lock nut and washer on the nipple.
John
Cacher_Chick
Test, Don't Guess!
If you are up to doing some cutting, getting the nipple out shouldn't be too bad.
If you can't find a deep enough escutcheon, it's gonna need to come out if you want to hide it.
Otherwise, you just need a new trap adapter, some of which is what you just removed.
quote; I guess I need to find an adapter that will mate the 1-1/4 trap adapter.
You HAD one, it was the brass piece you removed. There would be NO reason to reinstall the same thing. There are lots of ways to remove the nipple and you do not have to worry about the threads on the end of it. BUT, I would put the brass piece back on it first so the nipple does NOT crush and jam in the cast iron tee. In fact, it may NOT be a tee, but rather a cast iron elbow which would NOT break under pressure.
wolfpacknc
north carolina
^ I meant find a smaller adapter that can still be covered by an escutcheon, but I realize I didn't make that clear.
So at this point, I can cover the nipple + nut connection with a 1-1/4 escutcheon I found at home depot. So can I just slide the tailpipe into the nipple and use a 1-1/2 zinc nut and 1-1/4 washer? I was able to fit this together at home depot, looked fine to me, but not sure if that's considered OK.
JohnjH2o1
Florida
It would work better if you used a 1-1/2 trap with the 1-1/2 x 1-1/4 washer on the tail piece from the sink.
John
wolfpacknc
north carolina
OK I finally tried and got the nipple out. I think know what needs to be done now. Thanks for your help everyone.
When connecting the new brass desanko do I just use some teflon tape?
