ilabadie
We're on our third plumbing fix from the builder. The first one was a hot water line re-route after we felt the warm tiles on the kitchen floor (slab leak). The second was on an exterior wall on the other side of the kitchen. There was a tell-tale water stain on the stucco which the builder didn't want to take care of at first. These geniuses actually turned off all the water to the house and then looked at the water meter at the street and claimed thast since the meter didn't move that there wasn't a leak. Kind of like looking at a clock's hour hand and claiming time has stopped when there is no minute or second hand. We forced them to bust open the outside wall. There the leak was and they fixed it. Now, there is a leak from our 2nd floor laundry room down to the alcove in the garage where the hot water tank is (was) located. We thought it was the tank, but after removing it and drying off the floor of the alcove, we ran a cold water load of laundry and the leak started again - it's coming from the ceiling of the alcove where the cold water inlet is located. The builder claims that the city prevented them from using pvc due to a pvc issue here in san diego county about 20 years ago. That issue turned out to be the fault of one pvc manufacturer, not pvc in general. The question is whether or not the city reverted back to the uniform plumbing code before these houses were built with copper lines. Whose fault is this?
We're still under the California mandated 10 year warranty so I need to know the best way to correct the problem. If the builder used M copper, won't I continue to have leaks in various places? I think the builder is just hoping to limp along with their plumbing contractors until the warranty period is up in 2012. I was wondering should I try and get the builder to line all the pipes after the repair or should I insist on a replacement with L copper? I'm checking the State plumbing codes to see whether or not the system is compliant with what the regulations were at the time these homes were built. Please Help - I know nothing about plumbing!!!!
