Pseudonym
I'm ok handling acids safely. So this should do it?
This is what I use. I buy it at Lowe's. Works beautifully!Thanks, Plumbs Away.
No septic, but I always use baking soda to neutralize before flushing.
Are you talking 30% HCl? What I have on hand is 15%, it did remove a bit more but lots is still there, especially under the rim. I went back frequently and used a paint brush to rewet the crusting under the rim too.
I haven't seen 30% HCl in years, but I admit I haven't specifically looked for it. I'll go looking if you think that strength will make the difference?
I can try the vinegar and pump overnight, I did it for three hours and it DID help, but didn't get it all off.Even plain vinegar would work IF you could leave it on long enough. Look at places like Carlsbad caverns - HUGE rooms, all dissolved by weak acids, but over millennia. For what you're dealing with, overnight should work...a stronger acid will just do it quicker, but at a bit more risk to you and your property should you spill or splash any anywhere.
I have a Lowe's nearby, I'll check it out. Thanks!This is what I use. I buy it at Lowe's. Works beautifully!
http://www.jasco-help.com/product/jasco-green-muriatic-acid
Glad it worked for you. It's just not a job I want to put a lot of time and effort into, and the acid dissolves the gunk in the rim channel that you otherwise can't get to. But, as they say, to each their own.In case anyone is interested, before going the strong acid route I gave this a try and it worked.
I sprayed a bone-dry under rim area with WD-40 and let sit for just over one day. Then, used my steam cleaner under the rim, the scale seemed to loosen up. Finally, used a piece of wall sand with my fingers and gently rubbed away all of the crust. Nice and shiny under there like the rest of the bowl.
Acid might have been easier, but I'd prefer not to use it if I don't have to, so long as I don't have to spend a lot of time scrubbing and scraping, either!
What is wall sand?That wall sand is awesome stuff. No scratching at all that I can see - dark room and shined a flashlight all around and everything shines like it's polished, except for the spots I couldn't get the wall sand onto very well with my fingers.
