Guy48065
I have baseboard fin/tube heat at my cottage. Copper pipe, 180° temp. I need to make a couple small changes to the layout thanks to some remodeling. Is it OK to use regular PEX as a flex connector from an emitter to the copper pipe, or must oxygen-barrier PEX be used even on short connections?
What's you opinion on using PEX in this application vs pricey flex connectors with compression ends?
