"reel" for BX cable?
Discussion in 'Electrical Forum discussion & Blog' started by mookie3333, Oct 24, 2011.
  1. mookie3333
    mookie3333 Member
    Dec 11, 2008
    NYC
    Hey guys- I know someone must have an idea on how to work neatly/efficiently with BX cable. The scenario is, I had 250 ft of 12/2 BX cable, and needed ~60 feet of it. There are 3 heavy guage zip ties on the reel (from H.D.), which I didn't want to cut because the whole thing would become unwound, and a big mess. So, I would pu ll the end through the ziptie, then the next, then the next, and repeat. This is ok for short cable lengths, but becomes a pain when I work with longer cable.
    Is there any type of cable reel I can buy, or build, that can hold the cable, and supply it when I just pull on the cable? I suppose it would have to hold the other end of the cable to prevent the whole thing from, unwinding. I know the idea is simple, I'm thinking about how I can build one, maybe from cast iron pipes/elbows, etc. Or would it be easier to buy one? please advise, thanks!
  2. hj
    Much, much easier to buy one, and a lot lighter than one made from cast iron pipe and elbows. They make them to reel out while laying on the floor, and also to fasten vertically to the walls.
  4. drick
    drick In the Trades
    May 16, 2008
    It is a cable spinner. You can buy it at any electrical supply house. Its not worth it if you are only going to use it occasionally (IMO anyway). Cut the zip ties, unroll whatever you need, and then you are done then get out your 69 cent a roll of electrical tape and wrap the tape back around the spots the zip ties were to hold the roll together.
    -rick
Similar Threads: reel cable
Electrical Forum discussion & Blog Using "MC Lite" (aluminum jacket) cable connectors Oct 13, 2016
Electrical Forum discussion & Blog Switching between AC and MC cable? Oct 13, 2016
Electrical Forum discussion & Blog Underground cable Oct 2, 2016
Electrical Forum discussion & Blog Surface mounted armored cable, or EMT? Sep 21, 2016
Electrical Forum discussion & Blog Limitations on NM cable in tall structures? Aug 18, 2016
