Red Jacket 50N1 control box help.
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by rhuian, Jun 25, 2012.
  1. rhuian
    rhuian New Member
    Jun 25, 2012
    Tulsa, Ok
    Bought this house a few years back and am just now getting around to putting my well to work. I pulled the pump out yesterday and this is what I found:
    RED JACKET, 1/2 HP 208/230 VOLT,60HZ,11H 7.2A,CODE
    L,50N1,3450 RPM,PT.179-314,3 WIRE
    There's no control box in the garage where the wires terminate. If there was one it was cut out. I need to find a diagram or person who knows what sorta Cap I'm going to need when building my own control box.
    Any pointers?
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    No sense in reinventing the wheel. Control boxes are not that expensive. Just get a 1/2 HP Franklin box and you are in business.
  4. rhuian
    rhuian New Member
    Jun 25, 2012
    Tulsa, Ok
    Thanks, Thats what I was initially going to do but I'd talked to a local guy who didn't think that my particular pump had a Franklin motor. It has a plastic cap on the bottom which lead him to believe it was one of the pumps where Red Jacket used their own motor. I looked for a Red Jacket CB but couldn't find one.
    Is there any real way to tell which motor I'm dealing with and does it matter? Will a Franklin box work either way?
  5. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    My Grundfos doesn't have a Franklin motor but I use a Franklin control box. Are you sure it is a 3 wire and needs a control box? Maybe it's 2 wires plus ground?
  6. rhuian
    rhuian New Member
    Jun 25, 2012
    Tulsa, Ok
    It has red, yellow and black. I think 2 wire plus ground would be black black and green?
  7. valveman
    Mar 15, 2006
    Lubbock, Texas
    With just red, yellow, black, without a green you can't be sure. They could be using red, yellow, black because that is the only kind of wire they had. Then they splice it to two blacks and a green at the motor. Really need an ohm meter to see if any of those wires are grounded. If one of them is grounded, it is a two wire motor. If the two lowest ohm readings addup to the highest ohm reading between the three wires, it is a three wire motor and needs a control box.
  8. rhuian
    rhuian New Member
    Jun 25, 2012
    Tulsa, Ok
    Thanks, I'd already picked up a 1/2 horse control box from Lowes and wired it up and it works!
  9. Winter
    Winter New Member
    Jun 23, 2015
    Minnesota
    rhuian - What was the model number of your control box? I have the original Red Jacket control box , with the exact same pump as you specified... but I believe the relay is fried. It is NOT possible to find a replacement..... so before I contact someone to pull the old pump, I want to try a new control box first.???
Similar Threads: Jacket 50N1
Pumps and Tanks Well Forum & Blog. Water is life. Red Jacket Control Box May 10, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Red Jacket Hydro Servant replacement Jan 29, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Red Jacket Motor Jan 30, 2009
Pumps and Tanks Well Forum & Blog. Water is life. CENTIPRO control box problems for Red Jacket Dec 16, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Red Jacket Submersible Pumps----any good? Jun 26, 2008
