knarfknarf
Hello All,
I am hoping for some help. I am doing an oil to gas conversion in a 1500 sqft bungalow here in Ottawa Canada. I am converting this house into a duplex. The bungalow is 48' x 26' with 8' ceilings. Both units will be three bedrooms. It will be a shared heating system with two zones and I will be doing the install work myself and having a gas fitter to do the hook up.
The furnace I have purchased is a Rheem RGFD-07EMCKS furnace and I need to purchase a heat pump and a casecoil.
I am interested in this heat pump RUUD UPQL030JEZ HEAT PUMP 2.5 TON 15 SEER 410 but not sure which case coil would go with this setup. Here are my choices
1) RCFLHM3824CC RHEEM CASE COIL 2.5-3.0T 410A MULTI POSITION GREEN or
2) RCQD-4821AS RHEEM RUUD CASECOIL 16/18 SEER 48BTU 21"
I am not hooking anything up... I have removed all the old equipment and I am installing the furnace to the existing duct work. I am simply asking which combination is the best….
Everything else will be installed by a licensed HVAC installer. All I am trying to do is lower an incredibly expensive install quote.
Any help or suggestions for a setup using this furance would be greatly appreciated.
Thanks
Frank
Thanks
Frank
