recirc loop ok can't add branch
den
Currently have a hot water recirc loop to master bath. Grundfos pump is attached to hot water return line (upside down) and tee'd between the water supply check valve and expansion tank at the HWH. That works ok. When I put a comfort valve between the hot & cold water under the kitchen sink it has no affect.
Kind of acts like a check valve is somewhere in the system, more than likely I don't understand the concept. Florida house, so cold water plumbing is either coming up thru the slab or hidden in the wall which prevents me from visually checking beyound the hwh connections
Anyone have some advice
Jimbo
San Diego, CA
You are mixing apples and oranges. The existing recirc loop is circulating water at a fairly low volume. There is very little DP on the hot line, not enough to open that Comfort crossover valve.
den
Jimbo
Based on your input I guess I need to put a small recirc pump under the sink
ie: autocirc1 from Laing??
Den
Jimbo
San Diego, CA
I would not recommend mixing a recirc loop and a retrofit pump. I would check with grunfos on the Comfort system and ask them if there is any way to make that work alongside a dedicated recirc loop.
I guess a Laing under the sink maybe would be transparent to the recirc loop, but I am not positve about that, either. Possible unforseen issues.
den
Sent E-mail to Grundfos
Thanks again for the input.
Sent an E-mail to Grundfos ==
Den
comfort
I install the comfort pump on the hot water outlet as usual, (not at the return lines connection to the tank), with the comfort valve under the sink. You may need a spring loaded check valve where the dedicated recirculation line connects to the heater to prevent chatter.
den
not much room
All the examples I have seen show the pump location as you describe.
Since this pump has been in place for about 8 years it seems the reason
it was installed on the return line was that the installers did not leave
themselves enough room to attach the pump between the hot water outlet
pipe and the wall. Outlet pipe makes and immediate 90 deg. turn at top of
tank then enters wall within 8 to 9 inches. FYI on the return line before it
goes into the pump is a spring valve. If it is possible to relocate pump per
your suggestion would that create more DP than the way it is currently .
"Jimbo" thought they may be a chance of conflict between the dedicated
loop & the cold water recirt. Your thoughts.
Thanks,
Den
pump
You are confusing apples with oranges. The pump was put where it was because that is the proper location for the original circulation system. NOW, you are adding that "orange" and for that the pump has to be on the heater's outlet, because you are creating a 'hybid" system and for that you have to let the Comfort system be the primary one and your original circuation system, ride on its coat tails. It will work, but only the way I have described it.
den
HJ - don't shoot me
I am only attempting to get hot water to the kitchen sink quicker - and
I tried the comfort valve because of a suggestion by the local plumbing
supply shop. Do I have two options? One: Purchase a comfort system
pump and have it installed as you described (not good at sweating pipes) . Two: Put a autocirc1 type pump under the kitchen sink (this I can do).
DEn
Solsacre
Arkansas
You've got to visualize the system under the floor. It is a loop. you are working on a branch of that loop.... withiout more exact info we can't help you on, if this will work.
Use your mind's eye... will this extra pump work or ad problems.....
a rec pump adds no pressure, it only creates flow........:eek:
will the two pumps create flow that is complementry, or will there flow clash.?
It's in the exact application that will see a solid system.
good luck
dances-with-pumps
pump
You can do it either way. The Comfort pump does not use soldering if your heater is connected with corrugated flexible supplies. It fits between the heater and the supply pipe. You get a better pump with this system than the small one with the AutoCirc type installation. If you use the Comfort pump remove, or at least unplug the present circulation pump.
den
Thanks to all
Jimbo, HJ, Solsacre
Thanks all for the help. Let you know the outcome.
Jimbo - I was a ping jockey (sonar) on a destroyer USS Damato
in the early days of the nukes. Never had much luck
picking you guys up.
Den
