recirc loop ok can't add branch
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by den, Jan 14, 2007.
  1. den
    den New Member
    Jan 14, 2007
    Currently have a hot water recirc loop to master bath. Grundfos pump is attached to hot water return line (upside down) and tee'd between the water supply check valve and expansion tank at the HWH. That works ok. When I put a comfort valve between the hot & cold water under the kitchen sink it has no affect.
    Kind of acts like a check valve is somewhere in the system, more than likely I don't understand the concept. Florida house, so cold water plumbing is either coming up thru the slab or hidden in the wall which prevents me from visually checking beyound the hwh connections
    Anyone have some advice
  2. jimbo
    jimbo Plumber
    You are mixing apples and oranges. The existing recirc loop is circulating water at a fairly low volume. There is very little DP on the hot line, not enough to open that Comfort crossover valve.
  4. den
    den New Member
    Jan 14, 2007
    Jimbo
    Based on your input I guess I need to put a small recirc pump under the sink
    ie: autocirc1 from Laing??
    Den
  5. jimbo
    jimbo Plumber
    I would not recommend mixing a recirc loop and a retrofit pump. I would check with grunfos on the Comfort system and ask them if there is any way to make that work alongside a dedicated recirc loop.
    I guess a Laing under the sink maybe would be transparent to the recirc loop, but I am not positve about that, either. Possible unforseen issues.
  6. den
    den New Member
    Jan 14, 2007
    Sent E-mail to Grundfos
    Thanks again for the input.
    Sent an E-mail to Grundfos ==
    Den
  7. hj
    comfort
    I install the comfort pump on the hot water outlet as usual, (not at the return lines connection to the tank), with the comfort valve under the sink. You may need a spring loaded check valve where the dedicated recirculation line connects to the heater to prevent chatter.
  8. den
    den New Member
    Jan 14, 2007
    not much room
    All the examples I have seen show the pump location as you describe.
    Since this pump has been in place for about 8 years it seems the reason
    it was installed on the return line was that the installers did not leave
    themselves enough room to attach the pump between the hot water outlet
    pipe and the wall. Outlet pipe makes and immediate 90 deg. turn at top of
    tank then enters wall within 8 to 9 inches. FYI on the return line before it
    goes into the pump is a spring valve. If it is possible to relocate pump per
    your suggestion would that create more DP than the way it is currently .
    "Jimbo" thought they may be a chance of conflict between the dedicated
    loop & the cold water recirt. Your thoughts.
    Thanks,
    Den
  9. hj
    pump
    You are confusing apples with oranges. The pump was put where it was because that is the proper location for the original circulation system. NOW, you are adding that "orange" and for that the pump has to be on the heater's outlet, because you are creating a 'hybid" system and for that you have to let the Comfort system be the primary one and your original circuation system, ride on its coat tails. It will work, but only the way I have described it.
  10. den
    den New Member
    Jan 14, 2007
    HJ - don't shoot me
    I am only attempting to get hot water to the kitchen sink quicker - and
    I tried the comfort valve because of a suggestion by the local plumbing
    supply shop. Do I have two options? One: Purchase a comfort system
    pump and have it installed as you described (not good at sweating pipes) . Two: Put a autocirc1 type pump under the kitchen sink (this I can do).
    DEn
  11. solsacre
    solsacre Plumber
    Nov 16, 2006
    Arkansas
    You've got to visualize the system under the floor. It is a loop. you are working on a branch of that loop.... withiout more exact info we can't help you on, if this will work.
    Use your mind's eye... will this extra pump work or ad problems.....
    a rec pump adds no pressure, it only creates flow........:eek:
    will the two pumps create flow that is complementry, or will there flow clash.?
    It's in the exact application that will see a solid system.
    good luck
    dances-with-pumps
  12. hj
    pump
    You can do it either way. The Comfort pump does not use soldering if your heater is connected with corrugated flexible supplies. It fits between the heater and the supply pipe. You get a better pump with this system than the small one with the AutoCirc type installation. If you use the Comfort pump remove, or at least unplug the present circulation pump.
  13. den
    den New Member
    Jan 14, 2007
    Thanks to all
    Jimbo, HJ, Solsacre
    Thanks all for the help. Let you know the outcome.
    Jimbo - I was a ping jockey (sonar) on a destroyer USS Damato
    in the early days of the nukes. Never had much luck
    picking you guys up.
    Den
Similar Threads: recirc loop
Plumbing Forum, Professional & DIY Advice Recommendation for small expansion tank for potable water recirculation loop Jan 12, 2016
Plumbing Forum, Professional & DIY Advice Passive hot water recirculating loop Dec 22, 2014
Plumbing Forum, Professional & DIY Advice Passive recirculation loop with mixing valve at heater? May 5, 2014
Plumbing Forum, Professional & DIY Advice Check valves in hot water recirc loop Feb 2, 2014
Plumbing Forum, Professional & DIY Advice Hot water recirculation loop Nov 30, 2013
