Recessed light in bath
Discussion in 'Electrical Forum discussion & Blog' started by BJ James, Jan 30, 2009.
  1. BJ James
    BJ James New Member
    Jan 30, 2009
    Hi,
    I'm going to be installing a recessed light in a main floor bath. The attic is insulated. Is there such a thing as a IC /wet location recessed light made for remodelling(not new construction). I'm hoping not to have to crawl around in the attic.
    Thanks,
    BJ
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    It will not need to be rated for a wet location
    (D) Bathtub and Shower Areas. No parts of cord-connected luminaires, chain-, cable-, or cord-suspended luminaires, lighting track, pendants, or ceiling-suspended (paddle) fans shall be located within a zone measured 900 mm (3 ft) horizontally and 2.5 m (8 ft) vertically from the top of the bathtub rim or shower stall threshold. This zone is all encompassing and includes the space directly over the tub or shower stall. Luminaires located within the actual outside dimension of the bathtub or shower to a height of 2.5 m (8 ft) vertically from the top of the bathtub rim or shower threshold shall be marked for damp locations, or marked for wet locations where subject to shower spray.
    Unless you install the sprayer head where it is spraying on the light then damp location is all that is required. An enclosed trim will make the damp location compliant.
  4. BJ James
    BJ James New Member
    Jan 30, 2009
    So any suitable sized recessed (and IC rated) light will work and all I need is a trim kit? I assume they're readily available at most hardware stores?
    Thanks for the info.
    BJ
    edit: I just realize that in my first post I didn't mention this light is going in the shower. Am I still good?
  5. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Yes you did
  6. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    Just make sure with the light manufacturer that the light and trim are rated for that application which will be "damp". In addition, the bulb specified is the only type you can use so pay attention to that. The problem with this setup is that people don't realize how much water splash hits the ceiling during a shower, especially when washing your hair. Look up during or after your shower to see how much water is up there.
    They make recessed lights for showers with trim kits that allow an exposed bulb but I would prefer to see an enclosed bulb with trim that seals against the ceiling material. What is required and approved vs. what I like are two different things.
Similar Threads: Recessed light
Electrical Forum discussion & Blog Recessed light in fire rated ceiling? Nov 16, 2016
Electrical Forum discussion & Blog Future Size of Recessed Lighting Cans? Apr 21, 2016
Electrical Forum discussion & Blog 3 recessed lights, switch at end? May 9, 2015
Electrical Forum discussion & Blog Question about recessed light Mar 1, 2015
Electrical Forum discussion & Blog Recessed Lighting Options for Kitchen Jan 14, 2015
