receiver for garage door opener
Discussion in 'Electrical Forum discussion & Blog' started by yaron, Oct 27, 2010.
  1. yaron
    yaron New Member
    Oct 27, 2010
    Israel
    I have stanley et380 garage door motor. the receiver stop working. It got supply of 24VAC from the engine box.
    I bought LM138 universal receiver that should work (according to manufacturer) with my motor.
    the receiver has 3 wires. two should connect in parallel with the manual switch and the third should connect to the "COM" terminal (i.e 12 or 24 VDC).
    I did not find any com point in the terminal. How should I connect the receiver ?
    I attached pic of the terminal
    thanks
    Yaron
  2. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Post the install instructions. These hieroglyphics are of not much use. How do you know it is the receiver and not the transmitter?
  4. hj
    IF the receiver gets its power from the motor box, it has to have TWO wires to it, not just a COM wire.
  5. yaron
    yaron New Member
    Oct 27, 2010
    Israel
    Thanks for your answers.
    Attached the install instructions.
    The old receiver gets its power from the Engine box, I asked about the new one.
    I bought new receiver with 2 remote controls so it is not relevant now where was the problem.
    thanks for any advice.
    Yaron
  6. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    Your wire colors don't seem to match the instructions, but if you believe it is installed correctly then, with a multimeter,
    confirm that you are getting 15 to 26 vac into this receiver,
    confirm that the voltage across the push button terminals drops to zero when the button is pushed and
    confirm that this receiver is drawing some current, possibly dozens of AC milliamps.
  7. yaron
    yaron New Member
    Oct 27, 2010
    Israel
    How it end up
    The motor is old and you can get only 24VAC supply for receiver.
    I add external supplier of 12VDC and it is working fine.
    Thanks
    Yaron
  8. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    Measure and record the current draw in case you ever need to troubleshoot this.
Similar Threads: receiver garage
Electrical Forum discussion & Blog Electrical supply to barn and garage Feb 9, 2017
Electrical Forum discussion & Blog Detached Garage Connections Nov 14, 2016
Electrical Forum discussion & Blog Conduit Underground from House to Garage (+water) Sep 29, 2016
Electrical Forum discussion & Blog Requirements for Garage Sub Panel Aug 5, 2016
Electrical Forum discussion & Blog Adding subpanel to new garage Jan 14, 2016
