Ran over the well cap, reconnected wires no water pressure
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by ronivw, Dec 11, 2010.
  1. ronivw
    ronivw New Member
    Dec 11, 2010
    phoenixville pa
    Ran over the well cap this afternoon collecting leaves. The electrical wire got cut and I have reconnected it. The well cap is in the trash and I have not replaced it yet. Used the water for a couple hours, flushing the toilet, drinking water. Water pressure started to drop when I took a shower. When I first checked the gauge I was getting 20 psi, now the pressure is at zero and will not build. Any ideas what to check. Supposed to ran like crazy tomorrow.
  2. Gary Slusser
    Retired
    I'd check the splices you made putting the cut wires back together.
  4. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Current is what moves motors. Check the current draw with a clamp-on ammeter.
    I can't seem to pull it up right now but there is a table in the NEC possibly numbered 400 something that gives max. current draw for several types of motors.
  5. ronivw
    ronivw New Member
    Dec 11, 2010
    phoenixville pa
    Re- did the wiring, and water is getting to the pressure tank, I replaced the pressure switch but it does not build pressure? It does not seem to be turning on or off. There 220v going into the switch and 220v out. Any ideas?
  6. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Check the voltage out at the well head. There might be some damage to the wiring you did not notice.
  7. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Is there power getting to the wires that you spliced? There could be an overload tripped or fuse somewhere before the splice at the wellhead.
  8. Gary Slusser
    Retired
    Since redoing the wire connections out at the well, and now you have water again but not enough pressure to shut off the switch, you probably have a water leak.
    Or you don't have the wires connected right and aren't getting 220v to the pump and it's running on 120v. You can use a meter and sharp pointed probes on the wires below your connections for 120v each to ground.
    Listen inside the well casing for water spraying. If so and you have a pitless adapter, you may have damaged the o-ring seal of the pitless or bumped the casing so the o-ring is not sealed. Or, you bumped the casing enough to cause a leak underground just outside the casing where the water line to the house attaches to the pitless part that comes out through the casing. My guess would be that the voltage isn't 220 to the pump.
  9. ballvalve
    Dec 28, 2009
    northfork, california
    Water leak in the well.
Similar Threads: reconnected wires
Pumps and Tanks Well Forum & Blog. Water is life. newly reconnected well problems Jun 21, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Lost pump wires down the well help Jan 15, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Wires pulled out of deep well pump, don't know where they go Nov 22, 2014
Pumps and Tanks Well Forum & Blog. Water is life. How do I test those water level indicator wires -- we have REALLY hard water and.... Dec 4, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Sealing pump wires in artesian well? Jul 22, 2013
