Quick Pressure Drop
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Mikeyboy, Dec 14, 2008.
  1. Mikeyboy
    Mikeyboy New Member
    Nov 29, 2008
    The water pressure in my home is about 80 - 90 psi. I have an expansion tank connected to my electric water heater and I have a watts pressure reducer after the water meter. When I open a faucet, the water runs normally for about 5 seconds and then you notice the water pressure change and decrease. I look at my water pressure gauge and the water pressure is reading 20 psi. Is it normal for water pressure to drop so much with just opening one faucet?
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    No it is not. Does your PRV have a strainer on it?
  4. Mikeyboy
    Mikeyboy New Member
    Nov 29, 2008
    I dont know. This prv came with the house and we've been in it for over 2 years now. The prv only has a pipe on each end.
  5. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    [​IMG]
    Shouldn't these two threads be merged as one¿ I mean we are talking about the same plumbing problem.
  6. Mikeyboy
    Mikeyboy New Member
    Nov 29, 2008
    Based on the Diagram, can I easily remove that strainer plug gasket?
    If I remove that, what should I be looking for?
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Likely some debris. Clean it and replace it. I read and answered your first post before seeing this one, so my answer here is just a tad different. Check the strainer.
  8. hj
    prv
    More likely the PRV is defective and needs replacement.
Similar Threads: Quick Pressure
Plumbing Forum, Professional & DIY Advice Very Quick Water Pressure Question Nov 9, 2010
Plumbing Forum, Professional & DIY Advice Quick kitchen sink drain and vent question Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Electric Water heater runs out quickly Oct 1, 2016
Plumbing Forum, Professional & DIY Advice Hot water comes quickly but recirculating pump is off? Jun 15, 2016
Plumbing Forum, Professional & DIY Advice Quick vent question (near main stack) Mar 26, 2016
