Quick disconnects on Fixtures and PEX
Rockycmt
New York Metro Area
I have an plan to more easily winterize my vacation home. It is in the NorthEast and it gets cold there. I use the home about once a month and I drain everything after using it, and turn off the heat. I do this by blowing all the water lines out of the fixtures and out the hose bib, and put auto washer fluid in the toilets. I am very successful at this. Never a frozen pipe. I do sometimes have some residual water in a flex line under a sink that freezes. Takes a few min to clear.
I would like to convert some 1/2 copper to Pex. It is more durable to this cold. And easy repairs can be made.
-I would like to have some quick connects on the main PEX to hook up my compressor to. I can make my own connect with some bushings but I need a quick connect from the main (well in this case) to the house line so I can tap in easily and drain.
-I would also like 3/8 quick connects under the sink. So I can easily just disconnect and drain the flex lines.
Do they make such disconnects? I mean disconnects like the ones used on hoses and air compressors. For potable/clean water.
And Simply reconnect when I arrive.
I would take an old 5/8 ID garden hose with a good connector, and cut the hose. I would then insert a common air quick-connect with a 3/8 NPT thread on it into it, and clamp that with a worm clamp. I would screw the garden hose to a garden hose threaded faucet. If I did not have such a faucet already, I would install a "boiler drain".
I am not a pro.
Rockycmt
New York Metro Area
any air hose quick connect. Pull the collar back, insert the air hose, then blow the water out.
I already do that today. That is how I drain the house. I have a boiler valve with a compressor connection on the valves. Compressor hooks right up.
My question is how can I make pex a quick disconnect in places? With no tools. I have reasons to make some disconnects during draining. I can not find any type of fittings. I did find ones for pressure washers but not sure they are potable quality?
And how can I make quick disconnects for under the sink.
I know these are out of the box questions. Figured someone here would know.
WorthFlorida
Solutions
Orlando, Florida
Between the air hose quick connect and the tee to the fixture I would install a ball valve. With a lot of air hose quick connects installed it also introduces another component that can fail. Keeping the valve closed while using water may prevent a possible flood. Quick connect air hose will work but they're designed for air not water. Over the years it might corrode or get mineral deposits that may prevent a good tight seal.
My brother, a vacation home in VT, uses air to flush out the lines in the garage that sits under the house. You may already do this but open the bath/shower faucets open in the middle position to be sure that it drains. My brother had a bath/shower valve body cracked after a one time instant hot furnace program crashed, the heat turned off and the house froze.
Bluebinky
Des Moines, WA
Make sure you have a good oil separator on the air compressor and use clean air hoses that have not been exposed to oil...
