Rockycmt
I have an plan to more easily winterize my vacation home. It is in the NorthEast and it gets cold there. I use the home about once a month and I drain everything after using it, and turn off the heat. I do this by blowing all the water lines out of the fixtures and out the hose bib, and put auto washer fluid in the toilets. I am very successful at this. Never a frozen pipe. I do sometimes have some residual water in a flex line under a sink that freezes. Takes a few min to clear.
I would like to convert some 1/2 copper to Pex. It is more durable to this cold. And easy repairs can be made.
-I would like to have some quick connects on the main PEX to hook up my compressor to. I can make my own connect with some bushings but I need a quick connect from the main (well in this case) to the house line so I can tap in easily and drain.
-I would also like 3/8 quick connects under the sink. So I can easily just disconnect and drain the flex lines.
Do they make such disconnects? I mean disconnects like the ones used on hoses and air compressors. For potable/clean water.
And Simply reconnect when I arrive.
