Questions About Replacing Home DWV
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by notacomputation, Mar 3, 2006.
  1. notacomputation
    notacomputation New Member
    Mar 3, 2006
    it's a bungalow, built in 1959, on a basement
    can i use ABS to replace the steel pipes i'm breaking out of the concrete.
    at the end of the line the pipes was not far below the cement with hardly any 0-3/4 fill. can i lay ABS the same way or do i have to put it deeper. can't go too deep because i need to meet up with the 5" that passes under the footing
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The simple answer is yes, you can use ABS in the same way. Keep in mind the minimum slope for a drain is 1/4" per linear foot. I see no problem with the thin layer of concrete at the end.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    I would use PVC B4 I used ABS.
  5. notacomputation
    Mar 3, 2006
    hey guys. thanks for answers
    still wondering what's the best way to go about the job? at what end do i start?
    i want to cut the main line to the street a few feet inside the footing and hook up with a rubber coupling for now. do the front yard later. i can borrow a chain cutter from the store but i'm not sure if they're safe to use on an old pipe. i don't want to damage the pipe that passes under the footing but just get a nice clean cut i can connect the new system
    another Q i have is the toilet. the toilet seems to be sitting right on top of the large vertical pipe but the plumbing book i have says to use a Y fitting. can i just do it the old way? i don't want to move the large vertical pipe becaues it's already right next to the basement stairs. i'm going to do the bathroom later and replace the old fixtures but not the layout
  6. Cass
    Cass Plumber
    Nov 12, 2005
    The rubber coupling needs to be a (banded coupling) will have a solid smooth, not coragated, stainless band around it, don't use the ones that just have a clamp on each end. Are you living in this or is this a vacation home. If you are living in this I would suggest you do a section at a time until you know what your into. If you cut it all out at once you may find your self in a situation that requires a plumber in a emergency situation. Not a good place for you to be in unless your best friend is a plumber. :)
Similar Threads: Questions Replacing
Plumbing Forum, Professional & DIY Advice Finally Replacing My Late 90s No Flow Gerbers And Now Plumbing Questions Have Come Up Sep 20, 2016
Plumbing Forum, Professional & DIY Advice questions on replacing Mixet cartridge. Jul 3, 2015
Plumbing Forum, Professional & DIY Advice Questions Replacing Clay Sump Basin and Drain Tile Mar 28, 2014
Plumbing Forum, Professional & DIY Advice Replacing DWV for bathroom reno - wet venting questions Aug 15, 2012
Plumbing Forum, Professional & DIY Advice General questions on replacing water service DIY-style Apr 11, 2009
