Question on using IO to clean WS resin
JustaDIYer
Novi, Michigan
Ok. So I'm doing a resin clean with IO and let it draw in and unplugged the control valve to let the solution soak.
Should the valve still be sucking thru the brine tube? And water draining out the drain tube? And it seems like there's water flowing thru the valve. Is this right?
You need to also close the path through the softener to prevent water from flowing. Normally you will have a bypass valve of some sort.
Mialynette2003
Ocala, Florida
If the uni is is a draw cycle and you unplug it, it will remain in the draw cycle with water running through the system to the drain. I would not recommend putting it in bypass to allow it to "soak". If you want a real good cleaning, do a back to back cycle adding IO for both cycles.
JustaDIYer
Novi, Michigan
Yes. I did the second method. Mixed IO in a bucket and let the brine draw that. Unplugged the control and let sit for 20 min. Then hooked the brine tube back up and plugged unit in and let it finish regen. Didn't realize the valve would continue to draw while unplugged.
