Question on drain for utility sink install in basement
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Fastgt79, Oct 11, 2009.
  1. Fastgt79
    Fastgt79 New Member
    Oct 10, 2009
    illinois
    I am installing a utility sink in my basement right next to my sewage ejector pit. My plan was to install a drain trap underneath the utility sink drain then use a PVC wye fitting to connect to the ejector vent so that everything from the utility sink drains in the ejector pit and that I do not need to add another hole to the ejector cover. Is there anything wrong with my idea? What would be a better alternative?
  2. Cass
    Cass Plumber
    Nov 12, 2005
    What size is the vent?
  4. hj
    drain
    It will work. It may have some effect on the pump's operation if the water is hitting the float switch. It may turn it on or off sooner depending on when the sink drains.
  5. Fastgt79
    Fastgt79 New Member
    Oct 10, 2009
    illinois
    The vent is 2" PVC.
  6. Fastgt79
    Fastgt79 New Member
    Oct 10, 2009
    illinois
    If an ejector pump is similiar to a sump pump then it looks like the vent might be over the float switch according to the pipes leaving the sealed pit cover. If I add a hole to the ejector cover for a dedicated drain from the utility sink do I still need to use a wye and vent the new drain to the ejector's existing vent line? Or is it okay to just drain the utility sink drain directly to the pit without a vent given how close it is to the pit?
  7. Fastgt79
    Fastgt79 New Member
    Oct 10, 2009
    illinois
    So if I run the utility sink drain (with trap) directly to the ejector pit in a dedicated line do I still need to put a vent on the drain and tie it into the existing vent line?
  8. dcelite
    dcelite Plumber
    Oct 5, 2009
    Los Gatos, CA
    You need to run a vent for the sink trap and tie it into an existing vent 6" above the top of the sink.
Similar Threads: Question drain
Plumbing Forum, Professional & DIY Advice Bathroom sink remodel venting/drain question Friday at 1:36 PM
Plumbing Forum, Professional & DIY Advice Quick kitchen sink drain and vent question Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Drain waste vent run new bathroom question Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Liquid Fire drain cleaner question Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Small hot water heater solution? And related drainage question... Dec 21, 2016
