>why use galvanized
The library books I checked out on plumbing
said the pipes you can use cpvc, copper, galvanized.
The reason I went with Galv was my Aunt stores lawn tools
in this room and I thought the galv would be better in case
a shovel might hit it.
I haven't connected anything up yet so I can still switch
to something else. So would CPVC or copper be the
thing to use?
>why not drain'n flush the tank once in awhile instead
The Well guy said to do that too, there is a coupling on the back
of the tank but not the front so I will have to cut the copper
to get the tank out and will install a coupler on the front.
Since I am cutting the copper I thought it would be a good
time to stick a sediment filter on so when the tank
starts to fill up with sand, we would know it's time to flush
the tank out again. before the sand gets into the plumbing
system and screws up the faucet seals.
>Or work on getting the sand out of the well?
My Aunt has had a few Well guys come out and the general
consensus is with Floridas water table bouncing around, that
amount of sand was normal, and since the pump is
22 years old that it would be a waste of money to pull the
pump out and to wait till it starts to die then replace the pump
and rework the well.
>I would recommend staying with PVC and then using
>a PVC to brass or copper coupler.
I didn't know that existed, I asked the guy at the
plumbing store the best way to connect PVC to copper
and he recommended the PVC threaded male adapter
would I be able to get this (PVC to brass coupler )
at Home Depot or Lowes?
Here are some pictures of the front and back of
pressure tank a friend of my Aunts replaced it
13 years ago it was a little different size and he had
to use bricks to get it at the right height
Thanks for the advice so far
