Question about the Symmons Temptrol Valve
PhoenixPhyre
MA
I had started another thread about the banging in the shower pipes when the diverter is turned and I just want to make sure that what this plumber stated is legit. The seller's hired a plumber to come out and inspect the banging and he wrote a letter that stated:
"Called because tub and shower were chattering. Unit was checked and found no evidence of malfunction when used properly. Valve diverter should be positioned in either tub or shower mode and not in the middle; this type of valve (Symmons Temptrol) can under certain conditions make a thumping sound when it is shut off, This is normal and only happens occasionally and does not effect operation."
If this is the case, I don't want to be unreasonable or do you think I should get a 2nd opinion anyway?
Thanks for your help :)
Bob NH
New Hampshire
Does positioning the diverter in either the tub or shower position solve the problem? A diverter is not designed to be operated in the "between" position. It is a diverter; not a throttling valve. When it is in the "between" posiiton it restricts the flow and the energy from the pressure has to be dissipated. That will make noise.
When water is flowing and you shut it off quickly, the kinetic energy in the water moving in the pipes must be dissipated. That can make a noise, just as it does when you drop a rock on the floor. The energy is about the same as dropping a half gallon bucket of water from about 1 foot. You would expect that to make a noise.
If you want silence, then you need to find a way to dissipate the energy slowly and without causing the pipes to shake.
Jimbo
San Diego, CA
Just for peace of mind, I would ask the plumber or home inspector to measure the house water pressure, if this has not been done already. High pressure can agravate a water hammer problem.
