question about plumbing
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bronzemaxell, Jul 31, 2010.
  1. bronzemaxell
    bronzemaxell New Member
    Jun 24, 2010
    earth
    Hi
    i am in the process of hooking up my water filters
    i have a check valve between the well submersible pump and right before the pressure switch relay then to pressure tank.
    then pressure tank to sediment filter to pH filter to water softner to house
    i am aware of the in and out on the control valve
    can or if the water flow in reverse direction, will the resin in the tank back flow and travel to the house pipe?
    is it a bad idea to put an other check valve between pressure tank and sediment filter to prevent water to flow in reverse direction?
    [​IMG]
  2. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Please be sure you have a thermal expansion tank installed on cold inlet to your water heater to protect the tank and your warranty !
  4. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    get rid of any check valves. You don't need them and they add to the restriction of the system.
Similar Threads: question plumbing
Plumbing Forum, Professional & DIY Advice Bathroom plumbing question Tuesday at 11:20 AM
Plumbing Forum, Professional & DIY Advice Bath plumbing question Jan 30, 2017
Plumbing Forum, Professional & DIY Advice Finally Replacing My Late 90s No Flow Gerbers And Now Plumbing Questions Have Come Up Sep 20, 2016
Plumbing Forum, Professional & DIY Advice 1st Time Plumbing Rough In Questions May 10, 2016
Plumbing Forum, Professional & DIY Advice Oatey Plumbing Flange Question Jan 7, 2016
