Question about mixing 4 inch pipe types?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by SteveL720, Jan 14, 2007.
  1. SteveL720
    SteveL720 New Member
    Jan 14, 2007
    I have some cracks and holes in my sewer line leaving my house. I have exposed the parts that need replaced and have purchased what I think I need. I have a 4" 45 degree angle, a 4" coupler, a 2 foot section of 4" pvc pipe that I will cut down to what I need, and of course pvc glue. My question is, the new parts seem to be larger then the existing parts. The old 4" pipe says Type PSM ASTM D30334. The new 4" pipe says Type 1 SCH 40 ASTM D2665. I can tell the new parts are thicker but will these pieces fit when I cut out the broken section and use the new parts. My thinking was 4" fits with 4", but I don't want to find out the new coupler won't fit tightly over the older Type PSM 4" pipe. Please help before I jump in to this project. Thanks!
  2. nimrod
    nimrod master plumber
    Jan 14, 2007
    master plumber
    wisconsin
    the pipe you bought is schedule 40 pvc the existing pipe you have is 3034 ,sdr35 also know as thin wall sewer pipe . you can mix the two with 4'' ferncos or go buy the right pipe , you will still need the fernco to complete the repair .
  4. hj
    s&d pipe
    A good plumbing supply store will have "bushings" for the ends of the thin pipe to increase its diameter to that of sch. 40.
  5. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    They also make transition banded fittings for the different diameter pipes...
  6. solsacre
    solsacre Plumber
    Nov 16, 2006
    Arkansas
    As long as the ID (inside diamater) is the same, and you line up the parts well it'll work great. but getting the right pipe or the proper bushings to "up size" the 3034 is better.
    as long as the s*** goes down-hill and your not making a leak or a spot to catch "stuff"............. it'll work great.
    good luck
    dances-with-pumps
Similar Threads: Question mixing
Plumbing Forum, Professional & DIY Advice 1950 Renovation Questions Tuesday at 10:06 PM
Plumbing Forum, Professional & DIY Advice Bathroom plumbing question Tuesday at 11:20 AM
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Tuesday at 6:03 AM
Plumbing Forum, Professional & DIY Advice Moving kitchen sink and dishwasher, vent question Sunday at 6:24 AM
Plumbing Forum, Professional & DIY Advice Dumb, probably repeat laundry standpipe question Feb 16, 2017
