Question about builder problems
Eric28805
Homeowner
Asheville, NC
We hired a builder to remodel the master bathroom. We had him shrink the size of a closet, to make room for a soaking tub. The foot of the tub is where a sink was, so plumbing was already there. We then replaced the other sink with a new vanity (very little plumbing) and took out an old fiberglass tub/shower and got a new, tiled shower.
He did all of his own plumbing and it took forever (and he had to redo lots). He also got very confused by our tub. It seemed like it all worked though.
Then my wife took a bath and it leaked through the ceiling below when the tub drained. He was supposed to finish grouting and get his final payment tomorrow.
The original estimate was 2 weeks, $7,500, but with delays and "add-0ns" it's now more like 5+ weeks and over $10,000.
I don't trust him to fix the plumbing, so I want to bring someone else in. Should I wait until that is resolved before I give him a final payment? Should I deduct what it costs to fix it?
I now know not to let someone like him do plumbing, but what do I do in the short run?
I've attached the installation guide that came from the manufacturer.
Thank you
Eric28805
Homeowner
Asheville, NC
I opened up the ceiling to get a look at the plumbing. He was really, really confused by the tub and initially tried to use a test drain tube that came with the tub.
The pictures do NOT show where there could be a leak. Doesn't the tub have an overflow opening? I would NOT have used a trap with a union on the outlet. What is a "test drain tube"?
Eric28805
Homeowner
Asheville, NC
It was a clear plastic tube that could attach to the tub drain. They said they'd never seen one before. I think they threw it away.
The overflow is in the front and sends the water to the drain. None of the material really shows (but I attached what else I have)
Dj2
California
Hold the last payment and get an able plumber to fix the leak.
Definitely hold the last payment. Keep in mind that in most places, you are required to allow the contractor to try to fix things. If both of you agree that he is not capable and can agree on a lowered price to pay someone else to fix it, that's the easiest way out. You have much less leverage if you pay the whole thing before it is working satisfactorily.
Hopefully, your shower was put together better! FWIW, one study I saw long time ago indicated that 75-80% of them were not built per industry standards. Some fail sooner than others. Any work you've paid a 'professional' for should be done to at least the minimum industry standards...leaks are not up to standards!
Next time, consider putting a completion guarantee in your contract...5x longer than originally indicated is way out of line unless something extraordinary occurred. You don't want to rush perfection, but it seems like the guy was way out of his comfort zone...you should not have to pay for that.
FullySprinklered
Georgia
The builder has no idea what he's doing. Stop the builder now and get someone with experience in who does plumbing for a living. Free standing tubs take a lot more know-how than what your guy has.
WorthFlorida
Solutions
Orlando, Florida
If you can show a picture when its leaking it'd be of help. It may be nothing more than the union fitting needs to be snug up. At least this guy used primer on the glue joints but the trap should be all glue joints above a ceiling.
Eric28805
Homeowner
Asheville, NC
I might try that when the plumbers get here.
I'm glad it's a wooden bead board ceiling so it was pretty easy to take part of it down (and it will dry out)
Eric28805
Homeowner
Asheville, NC
He's agreed to pay for any plumbing done from below (and had previously agreed to bring in a plumber if there were leaks).
Not sure why he distinguished between from below and from above.
Eric28805
Homeowner
Asheville, NC
I'm a little bit worried about the shower now (and can't really test it until the glass gets here).
It did seem simpler than the tub though, and he used all Schluter products)
WorthFlorida
Solutions
Orlando, Florida
It seems this was done without a permit?
I just had my bath totally remodeled. The plumber had an air bladder and pumped it up in the drain to block it. Fill the base with water before the tile was installed, then he called for an inspection. The inspection was more for that the base did not leak and the top part of the drain. The drain was existing.
To test the shower before the glass comes you can cover the drain with plastic and tape. If you can remove the drain cover and then plug up the drain. Fill the base with water using a pail. Let it stand a few hours and check for leaks below. Then let the water drain and check for leaks again.
The bladder tool is the yellow hose. I’m sure there is a better name for it. This shower is on a concrete slab but your base should have looked similar unless a pan was used.
FullySprinklered
Georgia
Wow, that reminds me of a three-piece suit I bought at JCPenney in 1981.
Eric28805
Homeowner
Asheville, NC
The leak is from the very top, around the edges. The plumber thinks he used a floor drain and it just can't handle the water when the tub is emptied. The water that makes it into the pipes drains, but the spillover doesn't.
To finish emptying the tub, buckets of water got poured into the shower, with no problems, so it's probably ok.
Eric28805
Homeowner
Asheville, NC
first plumber to look at it said it would be an all day job and couldn't come back until May 15
second plumber found what I'd thought he'd find and it's going to take a couple hours (mostly because of having to cut the tile because the hole is in the wrong place)
Michael Young
North Carolina
Thank you
I would suggest you call the local inspections and pull your own homeowner-permit BEFORE anything else gets sealed up where you can't get to it.
