PVC vs Poly pipe around big trees
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by leak_chaser, Oct 27, 2013.
  1. leak_chaser
    leak_chaser New Member
    Aug 24, 2013
    South Carolina
    Which will stand up better to big tree roots?
    Thanks.
  2. hj
    Actually, maybe neither, because the biggest problem is usually the roots growing around the pipe and "choking" it. ANY plastic pipe can be squeezed closed by roots.
  4. Wrenched
    Wrenched In the Trades
    Apr 20, 2011
    Vancouver, BC
    Big trees and plumbing generally tend to not get along.
    PVC piping has less give than Poly so will tend to crack slightly sooner.
  5. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    If you really want to run a house supply past shallow tree roots, you would start at sch 40 PVC and work up from there. Poly pipe is not to be considered.
    To be really really conservative about it, you could even go with galvanized steel serving as a pull sleeve to encase plastic tubing.
  6. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    We sleeve poly all the time up here through 4" sch 40 PVC when we have a real rocky trench and under driveways. The stuff is damn near indestructible. Lay your 4" in the trench, glue it together, tape a golf ball to the nose of the poly & shove it in.
    All done.
  7. hj
    quote; The stuff is damn near indestructible.
    Maybe, usually, but I had a friend who had a sewer of it and the trees squeezed the pipe closed.
  8. craigpump
    Apr 12, 2012
    Really? A picture of that would make quite the conversation piece
Similar Threads: Poly pipe
Plumbing Forum, Professional & DIY Advice What fittings are there for polybutylene pipes? Nov 12, 2016
Plumbing Forum, Professional & DIY Advice Replace house side polypipe with PEX Jul 11, 2016
Plumbing Forum, Professional & DIY Advice Connectors for polypipe to sillcock? May 26, 2016
Plumbing Forum, Professional & DIY Advice ABS to Black Poly Pipe Connection May 14, 2012
Plumbing Forum, Professional & DIY Advice Rodents and Polyethylene pipe Mar 31, 2012
