pvc glue
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by gfe76, Jan 30, 2005.
  1. gfe76
    gfe76 New Member
    Dec 19, 2004
    Florida
    I had some pvc glue that was slightly gelled so I added some acetone (very similar to methyl ethyl ketone). It now seems to be the same consistency as new...anyone ever done this? I use this stuff so infrequently....more for a general purpose plastic glue than for pvc pumbing.... thanks for reply
  2. Plumber2000
    Plumber2000 Plumber
    Jan 13, 2005
    Eugene, Oregon
    As long as your not using it for a pressure application as with water line and or dwv then do with what you want with it, once it gels it's no longer good for the plumbing system.
  4. gfe76
    gfe76 New Member
    Dec 19, 2004
    Florida
    thaks for info
Similar Threads: glue
Plumbing Forum, Professional & DIY Advice Anyone heard of a PVC joint holding for 11 months with no glue? Friday at 12:25 PM
Plumbing Forum, Professional & DIY Advice Forgot to glue the PVC fitting after primer - Can I take off & re-use it? Oct 1, 2015
Plumbing Forum, Professional & DIY Advice kitchen sink pluged/glued/broken cleanout Apr 20, 2015
Plumbing Forum, Professional & DIY Advice Would a tailpiece be glued into waste line? Dec 11, 2014
Plumbing Forum, Professional & DIY Advice Can I remove glue and primer from pvc? Aug 4, 2014
