pump start relay - where to get just the relay
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Newlywed, May 21, 2014.
  1. Newlywed
    Newlywed New Member
    May 21, 2014
    Texas
    I have several start capacitors from failed control boxes. The start relays burn. Where can I get replacement parts for a Franklin Elec model 2801054915 1/2HP 230V. I only need the relay.....
  2. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Your controller is popping the caps or relays for a reason. Maybe it could just be a relay, but maybe not.
    If you look at the part number on the relay, check E-bay for the best price, or buy it from what you find on Google, You may and should find local. E-Bay's security sucks, local is best.
    It sounds like you may have other problems that may need to be fixed.
    Texas Wellman may be able to help you, If you are in his area. He is good.
    Welcome to Terry's Forum.
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    If you are burning start relays and/or start capacitors your pump is starting too much. Research how to eliminate the cycling.
Similar Threads: pump start
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump start often Nov 18, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Wild fire guessing details on pump and on well capacitor start box size Sep 19, 2015
Pumps and Tanks Well Forum & Blog. Water is life. frankin 1hp pump not starting up, but using electricity Jul 5, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Soft start pump motors Jun 9, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Jet pump hums and starts intermittently Jan 14, 2015
