Pump short cycling I think?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Rod M1, Aug 31, 2011.
  1. Rod M1
    Rod M1 New Member
    Mar 5, 2005
    Michigan
    I have a Simer 2802E well pump and it's pumping grate at 7 gallons a minute. But when you close the facet it will rapidly and repeatedly cycle on and off.
    Dues that sound like a leak? Would it be on the suction side or presser side?
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Sounds like two problems, a busted bladder and a leaky footvalve.
  4. Rod M1
    Rod M1 New Member
    Mar 5, 2005
    Michigan
    Thanks, "leaky footvalve" You mean a check valve right? This is a shallow well jet pump.
  5. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
  6. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    If you have a check valve between the pump and pressure tank, remove it. It will cause the switch to bounce the way you describe it.
Similar Threads: Pump short
Pumps and Tanks Well Forum & Blog. Water is life. Water pump stopped. Short cycles then stops. Jan 19, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pump is short cycling, not sure wha to do Jan 12, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Grundfos MQ3-35 booster pump short cycling Nov 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump is short-cycling. Tank bladder issue? Aug 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump Short Cycling Issue Jul 6, 2016
