I saw my water pressure getting lower and lower. Went out to find pump not running. Checked breaker, it was OK. Tapped pressure switch cover with wrench and pump came on. I had problems like this before and had to drain tank. So I drained tank (not all the way to no water coming out though) Turned pump back on, pump has a prime but still no water in tank. It is like the water is coming up from the ground and going through the pump but will not go into the tank and in the house. I usually can hear the water going into the tank. I have some sort of air pressure thing mounted on tank with copper line going to pump. Took it apart and it has a rubber gasket type thing inside with a spring, all held together with 6 screws with nuts. I have had to have this replaced once before. Do not know what it is called and the only writing says, this side toward tank. Christmas eve, family here, no water. Help! Please!!!
