pump queston
curley
moulton al
got a 275 gallon tote catching rain water. would like to hitch to a duel line deep well pump, complete with tank that i already got, going to use to water the garden. can this be done?
WorthFlorida
Solutions
Orlando, Florida
Yes, but the pump and pressure tank is over kill. For one, 275 gallons is very small storage to use for irrigation. Look at the pump chart and see how many gallons of water per hour or minute it will draw. Then divide that into 275. You'll also need float switches to turn off the pump when the water gets low. I assume that it is a tank pump combination. It can be used if you manually turn off the pump when the storage water tank is empty.
You did not state what and how much you want to irrigate. For a lawn, it can take thousands of gallons.
curley
moulton al
I know already its small tank , and I already had the pump, its just a small raised garden. I just need to know how to install having 2 pipes.
WorthFlorida
Solutions
Orlando, Florida
A jet pump is one piece with the jet attached to the pimp or the jet is down on the well. The smaller pipe feeds water to the jet, the larger pipe is the suction side. For a raise garden bed, just need a small utility pump with a garden hose attached. A small pump will work good with drip irrigation.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
First off, please don't double post.
If you only need low pressure for hand watering with a garden hose, you could plug the smaller of two holes on the inlet side of the pump. Keep in mind the pump would not produce much pressure so you could either not use the pressure switch or lower the setting so it can reach shutoff.
