Pump motor problem
Discussion in 'Pumps and Tanks Well Forum & Blog' started by hippodrome, May 7, 2008.
  1. hippodrome
    hippodrome New Member
    May 7, 2008
    I wonder if anyone has ever seen anything like this one:
    The half-horse capacitor-start motor on my shallow well pump won't start reliably. What I've found is that when the motor shaft is in a certain position, it won't start, just hums. I can get it to start by rotating the shaft about 30 degrees, off of this dead zone.
    The shaft rotates freely all the way around, nothing is binding. The pump runs and sounds normal when it does start. The starting contacts are pretty pitted, but it always starts fine if the shaft isn't in the bad spot.
    I was hoping it was the starting cap, but I suspect it might be one of the motor windings.
    Thanks
    Phil in Minn
Similar Threads: Pump motor
Pumps and Tanks Well Forum & Blog Re-assembling A Submersible 1/2 Hp Gould Pump Motor Monday at 11:48 AM
Pumps and Tanks Well Forum & Blog Pump motor burnout Apr 17, 2016
Pumps and Tanks Well Forum & Blog the motor for pump Dec 29, 2015
Pumps and Tanks Well Forum & Blog How to pick up motor and pump set drop in 350 feet well? Aug 10, 2015
Pumps and Tanks Well Forum & Blog Soft start pump motors Jun 9, 2015
